1971 evinrude 85hp outboard motor having spark issues
MitchBerg
Hello, I have a 1971 evinrude 85hp outboard. it worked fine started easy no issues, i was out on the water one day, brought the boat home stored it away. went to start it next year and it would not start.
my issue is im turning the motor over and it sounds good. but it wont get spark to start anymore. so i tested the 4 sparkplugs and i noticed im only getting sparks from one plug, the other 3 are dead. i tried buying all new sparks and nothing happen. i even replaced the sparkplug wires. if anyone could help me i would appreciate it. my first thoughts were that it might be the distributor cap, however i am not sure.
Remove the flywheel.---Remove stator and distributor cap.----Clean and set points to 0.010"----Clean all traces of dust on rotor and distributor cap.---Inspect anti reversing spring.
boobie
Remove the coil wire from the distributor cap and put a spark checker on it. Crank over the motor and if it will jump a 1/2" gap all that's left is the cap and rotor that could be bad.
kmivens
It may be a cracked distributor cap. I have the 1969 version of this engine and I was having the same problem a couple of years ago, weak or no spark on some cylinders. The cap had a crack in it. I picked up a used cap and that fixed the problem.
