1971 evinrude 85 horse power pack
jaydogg1504
Trying to convert a old power pack to new cdi 113-7123. Got everything hooked up now no spark on engine rotation just on one plug at a time when killing ignition changes which plug spark goes to if manually moving flywheel
emdsapmgr
That engine came from the factory with an amplifier. Is that what you are trying to replace with a power pack?
jaydogg1504
Yes flywheel has come off as some of the new wires go to the points. It is an amplifier assembly
SparkieBoat
did you grease or oil the top of the drive shaft where the fly wheel mates up? If you did, you have sheared your flywheel key. remove your flywheel and replace the key and completely clean all grease or oil from both surfaces and re torque your flywheel. check your magnets also.
That flywheel key can shear , but it does not affect ignition timing on those battery powered ignitions !
jaydogg1504
It seems lil spark I there as I can hand turn flywheel then turn key on and off and get spark to one plug. Then if I turn flywheel more and repeat it goes to another plug. Eventually sparks each plug. But no spark when turning engine over only at shut off
Post # 8 tells me you need to look at the starter motor , possibly it is robbing too much voltage from the system.--Or you need a new battery with plenty of power.---A mediocre battery on these simply is not good enuff !
SparkieBoat
remove all your plugs and see if the starter will spin the motor fast, check for spark on each wire. your motor needs to turn over pretty good RPM in order for proper spark.
This ignition system is run by the battery and not by the fast spinning magneto !!!!------------It was posted that there was spark when turning it by hand I believe.
jaydogg1504
I get spark on one plug at a time only when turning the ignition key off while turning over the engine no spark at all
See post #9------There was also a factory service bulletin to make a wiring change on the motor to put more voltage to the amplifier for start-up.
