1971 evinrude 40 hp no spark
shawn260
i have a 1971 evinrude ski twin 40hp and have no spark on either cylinder. i pulled the flywheel off and the coils are new and points don't look too bad. clean and gap looks ok. is there anything else i can test or check. again no spark on either cylinder. i could see no spark on 1 cyl, poss. points or condensor, but i have zero spark all around, any help would be great, thanks.
model number is 40153G.
tx1961whaler
Re: 1971 evinrude 40 hp no spark
There are 2 black wires coning out from underneath the armature plate (what the coils are mounted on...). Those are the kill wires. Disconnect them at their knife connectors and try it again. Each of those wires runs to one set of points. If they are grounded to each other or the block, it won't fire.
The flywheel gets torqued back down to 105 ft-lbs on those...
shawn260
ok i'll try that, thank you very much for the help and your time.
shawn.
tx1961whaler
Also, make sure that the points are gapped to 0.020" and are perfectly clean.
shawn260
ok i'll clean and set the points. thank you.
shawn260
cleaned and set gap on points, great spark on both cylinders now. thank you very much to everyone who replied to my post.
shawn.
