EvinrudeMadness
Thread starter- Joined
- Aug 5, 2016
- 5
I have a 1971 Evinrude 25hp that wont start. I have replaced the points, coils and condensers. I have rebuilt the carb except I have not removed the aluminum plugs in the carb. I do have spark. I tested the fuel pump and it will spurt gas when I pull the recoil. I have 105 psi and 110 psi compression on the cylinders. The plugs appear to be dry even thou my arm is soar from pulling it over with the choke on. Any help would be much appreciated.
