1971 Evinrude 18 hp help
skidder_211
I am very new to motors and have only played with a late 40s Johnson seahorse. Recently I was changing my lower unit oil and as it overfilled out the top some brow sludge came out (not a whole lot, but small amounts intermixed with the other oil). I believe this is a slightly leaking seal behind the prop where there was a little fishing line stuck. How do you go about changing this? I do have a manual but do I have to take the whole lower unit off or can I just unscrew the bottom halve of the prop shaft? The manual doesn't look like is has seals but O-rings that go on it at 2 places. Can I use the liquid sealant that is in a tube and can I just shoot that in it with the prop off and shove the prop on? I am hesitatnt to tear into it since I don't have lot of experience and it currently works (will get me from point A to point B). A previous motor I had I worked on it and couldn't get it to run after I put it all back together, I do not want to repeat this.
F_R
Honorary Supreme Mariner
You can replace the prop shaft seal by removing the skeg. However, it is easier if you remove the gearcase and turn it upside down to work on it. You can also replace the other seals and water pump impeller while you have it off.
There IS a prop shaft seal! Yes, fish line can destroy it. But my advice to you at the moment is pull out the fish line and drain and refill the gearcase with fresh oil. Then check it from time to time to see how it is doing. A few drops of oil intrusion is not a big deal, just change the oil like you are supposed to be doing anyway. But if you are getting serious water intrusion, time for a re-seal job.
EDIT: I see why you think there is no seal. OMC did not list the seal as a separate part that year. But it is still in there. It is behind the stainless steel fish line guard. The guard just pops out if it is still there. Lots of them have fallen out and been discarded. You have to look at an earlier year model to find the seal number.
64osby
I fully agree with F_R. A little sludge maybe just that. If the oil turns to a milkshake then reseal the lower unit.
skidder_211
I changed the lower unit oil and it looked pretty good (slightly darker than it was when it went in). However when I filled it up and the new oil came out of the top, some brown sludge came out with it. I will say of the total amount of oil/sludge that came out 85% was oil and 15% was some sludge. I kind of pumped 2 more times to get more oil in and get some of the brown sludge out which cleared up some (about 95% oil and 5% sludge). This sludge was not observed when the lower unit was drained. The water pump and top seal was replaced about 8 months ago so I didn't want to take out the whole lower unit. If I have to get a new seal, are you saying the diagram that is on this website (which is like my manual) is wrong? I can't buy those parts from this website?
oldboat1
could post a pic for more input, but it doesn't sound to me offhand like something that needs fixing. I would run it a bit, then check it again if concerned.
HighTrim
Thick dark sludge, is likely old grease, or congealed oil, that was sitting in a cavity somewhere. Don't worry about it. As stated, if you start changing your oil, and it is very milky and white, or worse full of water, reseal it.
