1971 Evinrude 100hp
toomuchtrouble
Manual is lost; need the resistance range for the motor. Got to check stater with ohms but don't know the range of resistance.
Also, if anyone knows, will the stater for the 60 hp do for the 100 hp?
Plus, if the rectifier blew, does that affect the diode and stater?-in other words do I replace them all-did the rectifier kill the others?
(Starflite 100 feature a 2 cycle 90" V4. The engine on the Mate 2 consists of a 2 cycle single cylinder.
It says Starflite but don't know anymore as to which one it is)
Daviet
Re: 1971 Evinrude 100hp
Welcome to the forum.
Don't have a manual for your engine, but if you go to the CDI website and look up your engine you can use their troubleshooting guide, I think they will list the specs you need.
Go to the BRP website and look up both engines and see if the part numbers match for both parts.
F_R
Diodes/rectifier can be tested, y'know. While technically, it is possible for a burned-out rectifier to fry the stator, that usually is not the case. Test, don't replace till you do.
