1971 century wiring harness? obselete!
boatstuff20
i recently aquired a 1971 century boat and am having huge problems finding anything as far as parts. the engine wiring harness is shot and we can't find replacement connectors anywhere they are all listed as obselete. found a couple diagrams online but not much more. please help does anyone know what we can do any cross references?:confused:
NYBo
Re: 1971 century wiring harness? obselete!
Welcome to iboats!:cool:
Finding exact replacements is almost definitely going to be futile. However, generic parts will work just fine unless there is something extremely odd about your setup. What engine do you have?
seabob4
Dude, it's almost a 40 year old boat. OEMs are lucky if they keep "generic" schematics 15 years...
NHGuy
You can easily redo the wiring using standard boat wiring stuff. Check out the stickies at the top of the forum. It's actually not too tough of a job. I'd use the ABYC color standards so your work is easy to repair and follow. They have a color key with about 8 or ten wiring colors. If you follow that you'll be up to standard!
As far as the engine stuff, put marine plug wires for your engine on it, find the correct gauge & color wires to the distributor, coil, alternator & battery in the engine shop manual. It's not Century specific, it's engine specific. Follow the engine information for wiring up the dash too. You can either be "period" correct by using the engine diagram & colors or you can be ABYC correct with their color scheme. Either way use the engine info to make up your parts.
