1971 9.5 hp Evinrude Sport Twin
Krajr427
I recently purchased this 1971 Evinrude sportwin and it will start but then immediately just dies out I'm trying to keep gas going through it we cleaned the carburetor and replace the floats we put a fuel filter in line to make sure there's nothing getting back in and engine will only run if we pour gas down the throat of the carb. we cannot seem to get it to suck gas from the tank and keep running if you pour gas into it it runs you know and we just can't get it to pull gas is there anybody out there that can help me please we replace the fuel pump completely we wanted to make sure that it's working, brand new fuel pump on it and like I said new floats in the carb the carb was completely cleaned out I'm just at wit's end and I don't know what else to do I don't want to throw any more money into this motor if it's not going to run at all. It has good compression. It's a clean motor and everything you know please if anyone can help me I would really appreciate it thank you.
Honorary Supreme Mariner
There is a brass fuel jet in the bottom of carburetor bowl.------Was it removed for cleaning ?-----------Does spark jump a gap of 1/4" or more, yes or no ?
F_R
I'm betting you missed the fixed jet that racerone mentioned. It is deep in the hole behind the hex drain plug. It must be absolutely clean without a hint of any dirt or varnish. But don't go jamming drills or wires through it. It is a precision part and too big is just as bad as too small.
Crosbyman
does it work ok when pumping the hose ? ,
do a blow test on the pump (air in OK,,, air backwards NO GO)
fuel inlet needle stuck ?? did you install the little pull down spring on the inlet needle
​eventually.... do a pump test... disconnect the carb inlet hose and spin the flywheel to see if fuel does flow from the pump OUT to the carb.
​In any event sqeeze the hose bulb...fuel should flow plenty while that carb hose is off (use tomato can to collect the fuel while testing)
do not give up !!
Krajr427
Thank you all for your advice. I am going to frantically work on it as I have a visit coming from the man who helped rebuild the boat the engine sits on. I Thank you all again. Now I have work to do.
Krajr427
Okay my friends, now after cleaning all the carb jets and replacing the fuel lines and fittings the engine runs but I have to continuously pump the fuel bulb. Fuel pump problem right? Please let me know what to do. Thank you my friends.
Take pump apart.---If diaphragm is ok then look for crankcase compression problems.----If diaphragm is not ok then replace it.----Yes they are available.----Or make one.
Krajr427
The bulb is leaking. I can't get the motor to fire on both cylinders now either. You can tell it's missing and not getting the boat up on plane. It is running better and better each time I run it and I think the fuel pump is brand new. I am going to replace the spark plugs and fuel bulb as I already replaced all the fuel lines and installed an in line fuel filter.
Does spark jump a gap of 1/4" on both leads , yes or no ?---Very important to answer that.
Krajr427
Racerone, they top cylinder has great spark, in testing as you asked I found the bottom cylinder to have no spark at all. Please advise me what to do next.
Crosbyman
how do you test for sparks
​ with the plug grounded or of the plug booth itself ??
if testing with the plug.... try another
​if testing off the plug booth to engine frame ground and no spark you need to plull the flywheel and rework the points/coil/condenser/plug wire
​ as a basic test
check the ohms from the faulty booth to engine ground... if the coil' s secondary winding is good you should see 7-8Kohms and up if you see infinite open then the coil, or plug wire is open or disconnected from the coil's high voltage pin ...not good
​in any event you need to recheck that side of the ignition syst.
​keep a it you are closesoe to happiness
Remove flywheel with a puller that uses 3 bolts with 1/4-20 NC threads.---Then post picture of what you see there.---Likely you will see 2 cracked coils or 2 new ones installed already.----Work on many of these motors and see that all the time !
Krajr427
Racerone, Pulled the flywheel there are two coils no cracks two sets of points and once I filled and reset them I have spark on the lower cylinder bur not as bright as the upper cylinder. Is that a bad set of points? Sorry no pictures I put the flywheel back on already.
Opinions always vary.---I set points using the flywheel or a timing fixture.--Points open at the correct time with that method , gets the strongest possible spark.---Do yourself a favour and learn all about the wonderful-----universal magneto------using google.----No time for me to get blisters on my fingers here.
