1971 85 HP Chrysler flywheel key sheared?
Vorden72
Removed the flywheel from second engine yesterday and noticed binding till fully removed. Closer look shows, I think, partially sheared key stuck in key way. See attached photo. Tried to knock out with hammer and screwdriver without success. Any experience with this or suggestions?
Nordin
Continue with the hammer and screwdriver it will come loose at last.
Maybe heat the area with a torch an continue with the hammer and screwdriver.
Vorden72
No Title
Thanks for advice Nordic. That worked as you can see by attached foto.
