1971 60HP Johnson Lower Unit Drop
BJ46
I want to replace water pump impeller but there is little information on pulling the hydro-electric shift control wires down through the exhaust housing.
There appears to be a rubber grommet on the cable sleeve passing through the exhaust housing. Service manual says to "soap sleeve and pull through" as lower unit is being lowered. Manual tells you to "do it" but not exactly "how" to do it.
Manual says to pull outer exhaust housing, but it does not appear to be in the way???????
I do not want to damage or break sleeve or wires. How much force will "pull" wires through housing? Should attempt be made to push grommet through exhaust
housing with small tool before starting the drop and pull? Any advice from someone that has done this will be appreciated. Thanks.
Honorary Supreme Mariner
It is ultra simple.-------As they say you need to use something to lubricate the cable when pulling it down.---Use liquid soap or penetrating oil.-----A new cable is spendy if you can find one.----Also you need to attach something to the cable so it can de pulled back up.----Work carefully.
BJ46
After unbolting lower unit, do you "just" ease it down down and the soapy wire sleeve will pull through without any other maneuver????? If so, how much force is required to pull soapy cable sleeve through the exhaust housing? Sleeve grommet appears to be VERY "tight" in the housing pass-thru. I DO NOT want to damage those wires or sleeve.
BJ46
Well.....I gave up waiting for someone that had "actually" performed the procedure to clarify more than just what the service manual simply says. Service manuals are notorious for leaving out a "LOT" of details and tips that one really needs to know to properly do the procedure. That is the benefit of these blogs.....IF....the right person responds. I was concerned about "pulling" wire and grommet....just how much force was required and tolerable. Without any qualified advice, I bit the bullet and went for it. I can say....from this experience.....soaping grommet and wire......it pulled easily. Doing any new procedure is more comfortable when one knows exactly what to expect. But.....most procedures are not textbook experiences.
BJ46
You were right!!!!!!! Got another problem. Want to replace lower drive shaft bearing housing seals. This engine has a "round" top housing. I can move it clockwise or counter-clockwise but can not get a "hold" on it to pull it up out of housing. You got another simple trick.....hopefully. Thanks for your replies.
I could rebuild a unit like that without looking for or glancing in a manual.-----Read post # 2 and then read post # 4
BJ46
Well....CONGRATULATIONS.........everyone is stupid, only in different areas. Experience does make things simple.
