1971 60hp Evinrude Triumph Steering Bracket
marleywars
Need some help locating the proper steering bracket for this engine. The motor will be going on a 16" fiberglass boat.
Most dealers will find you an adapter kit.---------Or you could make something with a used tilt tube from many makes and models of motors.--------Your steering would screw onto that tube.
marleywars
I just pulled the tilt tube from an 74 50hp evinrude. I just need to find the appropriate brackets to mount it.
F_R
Transom mount bracket available right here at iboats. You will also need the part to connect it to the tiller arm, also available here.
F_R
No Title
Like this----
