I just bought a 1971 evinrude 60hp model 60173c. I bought the motor not running and the guy thought that it was the timing and he couldnt get it to fire. I've check the compression all 3 cylinders are 120psi. Cleaned the carbs and got new plugs and tested nice bright blue spark. Now the motor will fire and run for a couple seconds then die out like it's not getting fuel. I put my hand over the carbs and they are spitting fuel Out of he body. I'm just wondering what would cause this? And if it is the timing how do I test the timing on this motor. Also could this be the reeds and how do I check them.
