1971 50hp super thunderbolt max rpm?
Barkspud
Hey guys sweet site. New and a pile of boats to play with. What the max rpm for this motor? prop size stock and or recommended. Thanks in advance I'd like to get a tach hooked up it is electric start.
carholme
Re: 1971 50hp super thunderbolt max rpm?
spud;
Don't know your s/n but if it is a 1971 it comes up as a model 1500101,
Parts listing:
http://www.crowleymarine.com/mercury-outboard/449.cfm
Oddly enough, the original Merc p/n for the tach, which you will see under MISCELLANEOUS PARTS/ACCESSORIES, 79-73370A3 apppears to be still available if you are adamant about sticking with the original:
http://www.marinepowerservice.com/B...Num/1115100/Doc_Part_nbr/63296/pickyear/1985/
Do you know what type of control box you have?
Gerry
Barkspud
spud;
Parts listing:
Gerry
Nope don't need to be original. Just want to hook one up. Not sure how and will any 12 volt one work.
Moody Blue
Nope. You need to buy a marine (outboard) type tach to be compatible with the ignition system. An automotive tach will not work.
