1971 4 hp Johnson 4R71 tell tale
foodman500
I saw the FAQ on adding a tell tale but I was wondering if anyone's done the modification to one of these small two cylinder outboards. Was wondering what the best spot to drill for a water outlet would be? any pictures would be greatly appreciated.
I have a pretty new water pump in the motor and do not see water coming out of the 6 holes. Should be a mist there from what I understand. same on my 77 Evinrude 4 hp which has a new pump, no water coming out.
F_R
Honorary Supreme Mariner
I really don't think it is necessary, but if you think you must, probably the easiest way would be to remove the flat exhaust cover from the side of the powerhead. You will see that the water flows up along the forward edge of it. Drill & tap the cover plate near the top of the water passage for your fitting. Be sure you restrict the flow to a thin stream, because any water you are bleeding off is water that is not being used to cool the engine. Use a new gasket on the plate.
oldboat1
running in a test barrel? Pop off the cowling and check the top of the head. If too hot to touch, it's running hot (shut it down). If it's pumping, you should get a bit of moisture on your hand when you hold it over the holes -- may not be much more than than that. Main thing is that it's not overheating. Depending on water temp in the barrel or the lake, head temp will be maybe 110 - 130 or so F. 160F is too hot.
foodman500
OK, I think it's running hot by the touch test, I'll get one of those infrared temp guns and check it to be sure. I was wondering if these engines use a thermostat? In any case it would be nice to know how much water is being pumped. Where is the exhaust cover in relation to another component on the motor?
F_R
No thermostat. Cylinder head will get pretty hot right around the spark plugs, so don't be fooled. So will the exhaust cover. The exhaust cover is the flat plate on the side of the powerhead. When you get it off, you will see that the exhaust fire blasts directly at it---the reason it gets so hot. Those motors should blow out a decent spray out the relief holes. Not a stream, just droplets blown out by the exhaust relief.
WayneMullannix
I have a 1989 Evinrude 4 hp model E4RCEC that starts and runs great for about 2 to 5 minutes. After that it shuts down and feels hot. I have installed a new water pump empeller and I get spitting water from the small holes on the shaft. Is there something in the power head that could be wrong and if so how do I check it? Does anyone have pictures from a service manual as to what to look for?
