1971 25hp Johnson outboard
dan.penick@yahoo.com
While out fishing, I was cutting across the water, when all of a sudden my motor jerked the boat terribly. I thought that I may have hit something, but did not notice anything of that nature. I can no longer go top speed because it jerks the motor terribly & at a lesser speed it still jerks, but not as hard. After the motor gets warmed up really good, it starts slipping/missing real bad. I was told it could be the forward gear teeth going bad, so I was told I need to replace the lower unit, looking for other opinions, please help!
flyingscott
First thing stop running it you may just need a shift dog and forward gear. If you have broken teeth on the gears you need more. Your options are rebuild the lower unit you have find a used one and hope it's good or replace your motor.
Honorary Supreme Mariner
Drain the gear oil and see what comes out.----Water / oil / any metal bits ?---Also see if you still have spark on both cylinders.
