1970 Mercury 7.5 outboard parts needed
Swanyt
I picked up a 7.5 mercury outboard and it is missing the stator. The recoil for the pull start needs repaired but that is easy. EDIT I am just looking to fix this up to take my grandkids out fishing. EDIT
Swany
tpenfield
Re: 1970 Mercury 7.5 outboard parts needed
I have a 1969 7.5 Mercury . . . a nice engine. It seems like the parts for these engines are either pricey or non-existant. Looks like you can get the stator - new replacement type part - for $250 ish :facepalm: on MarineEngine.com Mercury Marine 7.5 HP Outboard Motor Parts by Component or try the used one listed on eBay.
FWIW - I usually bring the oars when I go out with the Merc 7.5 . . . because with a 40+ year old engine, something is likely to fail. I have to rebuild the fuel pump on my engine over the winter. I replaced some seals on the lower unit earlier this year and also had to spend $50 on a fuel line connector :eek:
However, I figure that once I get things fixed, it should last a while. If I had a newer engine, then things would probably start to break in a few years anyway.
Swanyt
Do you have a manual, outboards are all new to me as i am a newbee. I just want to know about out baords because i have a 1970 chrysler 45 hp and it works great, i want the 7.5 as a troller motor but i need to work on it and the pull cord in inneed of a new rope and the stator is missing.
Thanks
Swanyt
Swanyt
The S/N is 2815395 1970 -1971 7.6 Mercury w/ Thunder inginition
tpenfield
I don't have a manual . . . tried to find one, but could not. I've been able to do most of the repair work though. . . the engine is pretty simple.
