1970 merc 9.8 dies when in water
jdkessel
my1970 model 110 9.8 merc #298xxxx dies when the lower unit is submerged. Allready replaced exaust gaskets, base gasket and another gasket.I replaced all the gaskets i could identify.Did not disassemble the crankcase. It runs great until I drop it in the water. After a few pulls it will start again but then die within a few seconds
Chinewalker
Re: 1970 merc 9.8 dies when in water
Hi JDK2,<br /> Typically, if a motor is allergic to water, it has low compression. The motor needs a fair amount of compression to help overcome the backpressure created by trying to burp the exhaust out underwater. Have you run a compression check?<br /><br />- Scott
jdkessel
scott,<br />No I have not.I inspected the powerhead as I dissasembled it and the componants all seem to be in good working order so I assumed that might not be the case. I will referance my repair manual and check that.<br /><br />Thanks jdk2
jdkessel
more info on motor!!<br />when the motor dies, fuel pours out of the carb is that normal when an engine quits
jdkessel
I ran a compression check.After 1 pull of the cord on each cyl i got a reading of 60, after 3 pulls on each cyl i got 110 i did each test four times my repair manual did not list correct compression, are these #s normal :confused:
dajohnson53
I'm no compression check expert, but I was taught to (1) remove both (all) plugs, (2) open throttle full (you'll have to put it in forward) and (3) pull the cord or crank the starter until the gauge stops rising. I usually pull the little engines about 5 -6 times. I've only tested two Merc 9.8's in my life - one from around '67 and the other '74. Both read 120 - 125. My guess is that if both are 110, and even, it is not a compression problem. But, I won't claim to be an expert on that.
jdkessel
I cleaned out the cyl and now get 115 lbs per.I was told to check for spark if good spark check carb. whats the best way to check these componants
dajohnson53
Spark: Basic test is to remove the plugs one at a time, have it connected to the spark plug wire, but ground the plug against the engine block somewhere. Pull the cord and see if it sparks within it's normal gap. If you're holding the plug, be sure to hold it with a well insulated pliers and some heavy rubber gloves or you'll get shocked. I prefer to work it so it sits in place grounded somewhere. This will tell you if it's sparking but will not tell you how strong the current is. Obviously you need a shady, darkish spot to do this.<br /><br />Better test is to buy an adjustable spark tester, or make one. Search on these forums to find out how to make one. I bought one for $10 from the local Snap-on tool guy -a Thexton 404, available many online sources too. I couldn't find an adjustable one in the autoparts stores around here. The tester I'm talking about is basically a clear tube with a spark plug wire connection at one end and a grounding clip at the other. The gap inside the glass tube is adjustable. You adjust the gap to the correct length (I was told 3/8 for my '74 9.8), hook one end up to the spark plug wire, the other to ground, pull the cord and see if the spark (1) jumps the gap every time and (2) is strong, sharp, blue (vs. weak, yellow, intermittent). <br /><br />If both spark plug wires test strong, you're good to go. If not, you've got to trouble shoot backwards - wires, ignition coils, switch box, and then back to the parts in the flywheel. I've not done that, but don't believe the troubleshooting is that difficult. Parts can be cheap or expensive depending on which ones. <br /><br />Search this forum for 9.8 spark for a bunch of threads on assessing and troubleshooting ignition issues.<br /><br />If this is an older engine with uncertain history, I'd sy go ahead and do the carb. It really is cheap, easy and quick. I did mine this spring with no prior experience, using a factory manual and it was no big deal (except I broke a plastic part and had to repair it with JB Weld -later replaced when I got around to it). I recommend at a minimum a carb gasket kit ($8) and a fuel pump kit ($8). A full carb rebuild kit for your engine will likely be around $60, so you might want to see if the other things get it running well before you invest in that. You also need a gallon of carb/parts cleaner with a dipping basket ($10 - but will last you a lifetime!), a can of spray carburetor cleaner ($3) and a can of or other source of compressed air. <br />Good luck on the project
jdkessel
the spark plugs on my motor have flat conductors with no gap adjustment is the process any different
