1970 merc 800 starts easy, runs weak...
ozarkjeep
compression is 120 in each cylinder, plugs are good, plug wires are good, has good hot spark, new fuel pumps, carbs cleaned out.<br /><br />timing at idle is 5 degrees, carbs almost closed, adjusted max timing to 20-21 degrees, throttles opengin all the way up.<br /><br />engine starts easy, and idles good, after appling throttle it just doesnt rev up.<br /><br />fresh gas, 50:1, bulb stays hard.<br /><br />any ideas? IM ready to sink it and start over.
papasage
Re: 1970 merc 800 starts easy, runs weak...
sounds like a gass probablem . rebuild carbs .
Clams Canino
Assumong all else is right:<br /><br />How are the idle needles set? Too lean and it'll fall on it's face accellerating.<br /><br />Also is it overpropped for the boat? Try dropping a couple pitches.<br /><br />-W
Clams Canino
Also try borrowing another gas tank and line. I've seen that before.
ozarkjeep
Its got whatever prop came on it, the engine came from a 19ft fiberglass ski boat, its now on a 16 foot aluminum boat, I dont think its any over propping issue. It has ran slightly better than this before, but that was with the max timing around 30 degrees max ( the way the engine came to me)<br /><br />are you thinkg starved for fuel with the tank fuel line swap?<br /><br />I have bypassed the fuel fitting, and ran a line straight into the top fuel pump... it is a brand new tank, bulb and line.? I guess it could be insuffecient for the engine..<br /><br />the idle/air mixture screws are about 1 5/8 each, if they were lean would it not eventually catch up and rev a little?<br /><br />ideas and suggestions are welcomed and appreciated!
Clams Canino
I always try another can to eliminate the external fuel system is all.<br /><br />Try them at 2 1/4 - sometimes they won't catch up.
