overkillthemighty
- Jul 6, 2012
- 13
I am a novice to boats, though I have a fair amount of experience with cars and engines. I bought a 18' boat with this engine for $300. The boat needed a lot of work, but the guy said he brought it to a shop and the engine ran fine (the wiring harness was cracked and gone, but I built a new one). I got the engine running, found that one of the sparkplug wires was not connecting and fixed it. After getting the boat and engine in good enough shape I put it in the water and hit a top speed of 45Mph (GPS Speed, the speedo was dead), and ran it for a good 2 hours with no trouble.
My trouble began 2 days ago. I took the boat to a different lake for the 4th, and it was not acting normal at all. It started harder than usual, but I thought it was the higher elevation. As I started out into the lake the engine did not seem to be pushing nearly as fast as usual, and a couple of minuets after I left the marina the engine started putting out a little smoke. I was hoping that it had sucked up some oil and was just burning rich, so I swayed a bit to try to get the tank to slosh, but the smoke started getting worse, so I cut it.
The top two cylinders were boiling water off when I flicked some on them, the middle two were steaming a little, but not too bad, and the bottom two were just a little too warm to touch. Also, when I first pulled the cover off, there was some smoke coming out of the middle carb. One of the spark plugs was not tight enough and some oil had leaked out of it. I pulled the 5 easily accessible plugs and they all looked a bit dry to me. I put them all in and tightened them properly. I cooled the engine down with a small drizzle of water down the heads, and when it stopped steaming I let it sit for a while. After waiting about an hour I headed back toward the marina at about 1/3 throttle (I pushed it up to full after a bit, and it seemed faster than before, but it was still only going 17 Mph) when I got near the marina I trolled around for a bit to see if the problem was a fuel mixture problem, but after about 5 minuets, it started smoking again. I cut it, cooled it, and headed back to the marina. I docked it and got the boat trailer, by the time I got back, the engine had a really hard start, but I got it up and on the trailer.
There are a limited number of variables between the last run and this one. The altitude difference between the two (The second lake was 1700' higher than the first). The fuel mixture (I did not have a can to pre-mix in, so I dumped the oil in and added the fuel after, but I then drove a good 60 miles, so it should have mixed up). Last, but not least, the engine ran for an unknown amount of time at idle without water (I had the earmuffs on and was trying to fix an electrical problem caused by the colossal amount of electrical noise the engine makes. It ran for a total of 2 min, and some time during that run some jerk tripped over my hose and didn't say anything about it or fix it.)
I feel that it is the last one, but I need to know where to go from here. People say it is not worth it to rebuild the lower unit, but I am on a university student budget and have time and some resources to work on it. What can be done? What needs to be done? Is it likely the engine is burnt up (will I have to pull it apart and look for scoring?) or is it more likely to be the lower unit? I am really prepared to pull the whole thing apart and try to fix it, but I need help knowing what to do. I have a service manual for the engine (That is how I rebuilt the wiring harness). Will that give me enough detail, or will I have to get additional info? I had called a few shops around here a while ago, and they all said they wouldn't even touch an engine this old, so I am on my own. Any help would be much appreciated. Again, this is my first experience with owning and operating a boat, so sorry if I did stupid things.
