1970 Johnson 85hp Ignition - Have you ever seen this?
Steel 6
I have a 1970 Johnson 85hp that has ignition problems. Upon looking for a "donor" motor for parts, I came across this ... looks to be altered using car ignition parts.
Has anyone ever seen this before? Does it work?
Thanks
RichardNaugle
Re: 1970 Johnson 85hp Ignition - Have you ever seen this?
do you have any more pics of this and did they change the spark plugs to fit the coil and which posts do all the wires go to if you can get the info I'm gonna wire mine up like this and then i can let you know if it works thanks rick
Bifflefan
Thats interesting, looks nothing like my '74.
wilde1j
Just because something can be done, doesn't make it a real good idea. Most auto ignition systems are not up to living in a salt or marine environment long term.
RichardNaugle
i don't know about where you live but up here in nova scotia just about every poor old boy is running a Chevy or gm car engine when there expensive marine gear goes south, with no problems,,for what it's worth it might not be right but it is economical..cheers
wilde1j
That it is.
Steel 6
I believe what they did was find a coil wire that works. Says it has ran well ...
bluestng
My 69 85hp has a car coil and works fine, was that way when I bought it. You need a coil, ballast resistor, and a capacitor.
Steel 6
Bluestng - I sent you a private message ....
Could you send me a simple diagram of how yours is hooked up .. so I can compare.
Steel 6
Well - I haven't heard back from Bluestng yet .... but this is what I have found ... You need a coil (internal resistor type), condensor and new coil wire.
I'm going to give this a try I guess. So we'll see what happens.
RichardNaugle
am eageley awating the results of your trail and error before i go out and burn up my own boat lol good luck rick satnding by
Steel 6
What I know/learned - and the final outcome ...
Ok - Here is the story - take it as you will ...
Well - it works
I now have spark on every cylinder. However, I found out my rotor and wires are badly worn. The cap doesn't look very good either. So I went online (and to my local parts store) and checked for parts and found out most are not made anymore/available and what is available is rather expensive to say the least. Although, you can make your own plug wires for this engine and save a bundle.
Thus I think I am going to call it quits on this engine. I have found a 1977 Mercury 115 Inline 6 that runs great and looks good - for $350, so I'm going to go that route. I attached a pic of it - and no he didn't use it on that boat :)
So... thats what I found out ..
tashasdaddy
Re: What I know/learned - and the final outcome ...
you best check for parts availability on a merc that old.
wilde1j
BTW, Mercury Marine is nothing like OMC/BRP when it come to parts for old motors. They stop making them way before BRP stops production.
bluestng
Sorry for the long wait, work has been crazy lately. The coil looks the same as the one from my 1987 Dodge Dakota. It is really cheap! Then you will need a ballast resistor and a capacitor. The extra wires are not hooked to anything, dont know much more about it but it does run like this.
