1970 Johnson 65 hp o/b. Boat goes--sometimes.
rickdb1boat
Do you mean upon acceleration or running at high speed? Does it do it when either hot or cold? Why were the carbs rebuilt? Because of this problem or did the motor sit for some time or was it something else?
tashasdaddy
Re: 1970 Johnson 65 hp o/b. Boat goes--sometimes.
check you compression , and it could be fuel pump, or coils, or power pack.
tashasdaddy
last year is not today, things change, check the compression , make sure the innards are good before you spend $.
