1970 johnson 60
xlvmax
Hello, just a quick question. To get the motor to turn over i have to spray a bit of gas into the carb each time i start it. Im thinking the carbs must be gummed up and not getting enough fuel. Any ideas? Thanks, Paul
F_R
Re: 1970 johnson 60
By "turn over" you mean start and run? Does it run properly once started? If it does, it isn't gummed up. Check your link & sync and choke.
