1970 johnson 25hp throttle issue
Robherold85
So here's the deal, I got a 70 25hp johnson motor. She runs like a top no problems starting or staying running. The only issue I have is when backing down from full throttle it's all or nothing! It goes from wide open to idling no matter how little I move it. Any ideas on a fix? Thanks in advance
FYI no steering to throttle linkage
Bosunsmate
Can you accelerate gradually?
Have you checked nothing is sticky with the throttle linkages for the timing and butterfly
F_R
Ignition coil dragging on the flywheel magnets??
Robherold85
No problems accelerating. It's just after its been full throttle and back down.
Bosunsmate
Have a look when the motors off. Check that turning the throttle to slow only slowly closes the butterflyvalve and then the timing
F_R
No Title
Perhaps you didn't understand my suggestion. If the coils are rubbing on the flywheel magnets, the rotation of the flywheel is constantly trying to rotate the armature plate (throttle) toward "Slow" or "Stop". While you are holding the throttle the throttle at "Fast", you are resisting that rotation effort on the armature plate. As soon as you back off from "Fast", you stop resisting that rotation of the armature plate and it spins around toward the "Slow" position.
See the heat marks on the ends of the coils, caused by friction of rubbing on magnets
