King-of-kings
Thread starter- Joined
- Nov 14, 2019
- 6
my little 1970 1.5 hp Johnson won't start. It has 90 psi compression, a new coil with an ignition module (I replaced the points & condenser), new plug wire, new plug boot & clip, It has what looks to be great spark. The ground strap wire that joins the mag plate to the power head exhaust plate was broken so I replaced it too. The carb was opened and cleaned. It has the original cork float, the brass tube in the carb is clean but I did not notice a tiny hole on the side of the tube like I'm used to seeing on these carbs....I looked it over several times but can't see a side hole....tried new gas in it and put some in the carb and the cylinder. No sir it won't even cough. Doesn't make sense to me. I figured it would run like a top.
anyone have one of these and can offer some useful advice?
Cheers
Jason
Cheers
Jason
