I have tried a few things and I'm still not getting a spark pasted the coil. here is what I have done. I've done all the test for the starter system, good to go. Replaced the amplifier, which came with a new coil. What he tests have shown. The amplifier is good , I get power to amplifier (12v) and I get around 180v when I turn on ignition, then I get 250v when cranking, but I get nothing out of the coil, it is almost like it is grounded. I tried the new coil and the old coil both do the same thing.
Anyone have a good test for the coil, maybe both are bad? If they are good any ideas why it is not going past coil. One other thing to verify is the wiring for coil. The old coil has a ground wire and a blue wire (that is where I get 180v/250v from) plus wire to the rotor assembly . The new coil just has a blue wire but a large metal tab for ground (at the mounting bolt) and same wire to rotor assembly.
Thanks for any help...its got me scratching my head.
