ShrimperJosh
Thread starter- Joined
- Sep 13, 2013
- 30
My wife and I just bought this boat a month or so ago. It is a '75 18 footer, v-hull, and is not in bad shape, other than a few cosmetics. It has the 1970 Evinrude 85 selectric, which is pretty clean outwardly. It had sat for a few years, so it was hard to start. I put a few drops of 2 cycle in the carb before cranking just for good measure and used a small tank with fresh gas (the tank in the boat had 8 year old fuel in it), and after a little patience it started. It seemed to need to be run out a bit, so I got her in the water and topped out at an astounding 8-10 mph! Fished for a few hours, didn't take on water, so that part of the test was good, just wouldn't run well at wot. Got it home and was going to clean out the carbs, but thought I would just try to clean the high speed orifices and, at least in a tub filled with water, it will run wot! I hope to have time to take her out for one more run before the winter sets in, and will change water impeller over the winter. Hopefully by sharing this experience, someone will benefit by checking the jets before getting to far into the carbs, when it may not be needed (yet). I should add that I ran a quart of Seafoam and a gallon of gas/oil mix before cleaning the hs orifices, and I will be running it through again now that they are open. Happy boating!
