1970 evinrude 85 compression reading
wannabewelder
Hi, don't have my FSM yet but I bought a 1970 85hp Evinrude and it comped out at 130is on all four. Starts and runs nice but I was wondering if it's a bit low? I have a 55hp that is over 150lbs and a 40 that is at 115lbs. Runs pretty nice but just consider whether to maybe hone an ring before one hangs up and costs me a scored head.
Thanks in advance.
boobie
As long as it runs good for the age of the motor I'd leave it. Maybe run some OMC Engine Tuner through it.
F_R
Honorary Supreme Mariner
Agreed, it is good 130 & equal. Some engine cleaner won't hurt and might even be good for it as preventative maintenance.
F_R
On that subject, we had many water pump failures when those motors were only two or three years old, resulting in catastrophic engine damage. I suggest you inspect the water pump, and if it still has the original aluminum pump housing, replace the entire pump with the kit which includes a plastic housing with stainless steel liners. But if it has already been changed, all you need is a new impeller.
wannabewelder
thanks all! Well it got cold out here so I can't run it in the bucket so i'll drop the impeller like you said over the winter.
