When I start the engine it runs rich spewing an oil cloud and spits raw fuel. Advancing the throttle in gear before it warms up just bogs the engine down and it stalls. After warmup it idles OK, but after prolonged idle it will bog down and foul the plugs. I checked that the choke is OFF, oil/gas mixture is correct, spark is present, changed plugs, points and rebuilt carbs many times. Motor runs fine at part power and WOT after plugs are cleared. Problem has been present almost since new. Any advice would be appeciated.
