1970 evinrude 4hp
torreshondaguy
hi guys im new to this forum my name is brian i just got a 70 4p evinrude motor ran good when i got it but would not run at low rpms so i rebuilt the carb, fuel pump also put new water pump and cleaned out water passages. motor will run but its an pain to start and then will run good at wot but then when i bring the rpm down it sounds like its loading up and it dies out and its hard starting. had it on the water yesterday ran good for hour on an off then died out and would not start untill this morning kinda stumped on this one. carb settings are 1.5 turn on high and low then i ajust when its running. have not messed with the points and condensors yet could that be it
Honorary Supreme Mariner
Fact.----The coils on these motors all failed / cracked.----Remove flywheel and you will find 2 new coils or it needs 2 new ones.
torreshondaguy
ok ill check coils tonight also how to i ajust timing or check timing with a light was going to check points read supose to be 20 thousands on fealer gauge
Shine the timing light at the 2 vertical marks on the magneto plate.----You will see the mark on the flywheel.--Check both cylinders.
torreshondaguy
checked the coils last night and both coils, points and condensers look brand new i tryed to check the timing but could not figure out where to shine the light i seen some marks on flywheel next to carb but not sure. tryed starting this morning and started up with a little trouble and wold bog and stall and finally got it to stay running but it wont stay running at low rpms and after going to full throttle comeing back to idle it dyes out i cant figure it out
Find the 2 vertical lines about 3/8" apart on the outside diameter of the magneto plate.----Shine the light at it and you will see the mark on the flywheel.----It should always fire inbetween those 2 marks !!
torreshondaguy
o ok i seen the 2 lines that are close to each other and then theres a mark on the flywheel ok i think i got it now ill try again when i get home. also how to i ajust the timeing if its out. could it be the carb settings i rebuilt it and set them both 1.5 turns out. its hard stating and just bogs and dies at lower rpms sorry for all the questions this little motor is killing me so aggravated with it already but ill check that timing again tonight an let u know thanks for the help thow
Compression test done on it ??-Carburetor settings are for initial start-up of the motor.---Then they MUST be adjusted by the operator once the motor is warmed up and pushing the boat !!
Rick.
You might try pulling the prop and checking to see if there is a wad of fishing line in there. That could give you some grief at low speed. Best of luck. Rick.
torreshondaguy
Checked compression 90 psi both also checked timing an it's just to the left of the hash marks still within the two lijes. Ran it to check timing and would not start backup after running at half throttle. So I double checked fuel pump an its working if I unplug fuel go in into carb an pull it it sho I get gas out of the pump now weird thing is if I disconnected the fuel from the pump the motor will idle like carp but it idles now i sent the float bowl suppose to shut fuel off but that pump keeps pumping I'm thinking it's flooded itself not sure
torreshondaguy
got it running at low speed i put old float and valce back in and ran perfect in bucket for half hour then pulled fuel line and let it run out of gas. let it sit for couple day and then last weekend i took it out started up fine ran for about 60 seconds and dyed restarted and seemed ok but then acted up bogging out but if i would pull the choke it would run
