1970 Evinrude 115 HP outboard Wiring
plizert28
I just bought a used 1970 Evinrude 115 HP Outboard motor. I have performed all test on all components and I am getting all of the right readings. But I am thinking that there is something wrong with the wiring at the terminal and this is why I am not getting a reading at Terminal 5 (output from Power Pack). I also do not have a safety ignition switch on the motor, it was removed prior to me buying. Should I replace this? I was also wondering if any has a better wire diagram than the one that is in the repair manual. It appears that it is a little incorrect. Also, can you let me know what wires need to be attached where on the key switch.
Thanks,
