1970 9.5 won't go forward
cammo
Im trying to get a 9.5 going. It will driver in revers and will go into forward if I hold the shifter down hard but only at idle. If I give it more throttle it will pop out and feel like it grinds if I don't stop pushing the shifter down. What I have done so far is replaced the broken detent spring for the shift rod and I replaced the bushing behind the forward gear due to slop in the old one. Also flopped the clutch dog. what else could cause this issue?
lindy46
Are the shift rods properly secured in the connector? The recesses in the ends of the rods should line up with the holes in the connector so the connector screws pass through the recesses. Also is the pivot pin passing into the hole in the shifter lever?
F_R
Honorary Supreme Mariner
Well you had it apart, so you are in a better position to diagnose it than we are. But it either isn't going fully into gear, or the clutch dog is totally worn out. If it isn't worn out yet, it soon will be with all the grinding. However, you say the forward bushing was worn out. Bad sign. If that was worn out, it is almost certain the pinion bearing is too. When that happens, the pinion moves to one side, and it is pretty much fatal to everything in there. Go in and take a better look, and keep an eye out for another lower unit.
