1970 650 4cyl 65 hp mercury CONTROL
compfast
Is it posible to get just the wiring harness for this control?......It's for a 1970 650 4cyl 65 hp merc......................as you can see in the pic all the wires are exposed and dry rotted............and my battery cables are green and freyed.
Scaaty
Re: 1970 650 4cyl 65 hp mercury CONTROL
Look for a good box on Ebay ...make sure they have popped it open and the switch wires aint junk too, like yours are, even though I can't see, I bet they are. The switch re wire would be a nightmare to resolder. Less room in the back of a ladies watch. If the wires off the switch are not crumbling insulation, fix up what ya can by butt splicing with waterproof connectors. Tape it up, good nuff. On the batt cables, you have 2 options.
One, just cut the damn things off. Get new 8 guage cable (Autozone), and if you go into the motor, just run new cables from/to the same spot where the old cables went to.
Now, either run them out the shift/throttle cable boot, or drill a hole in the lower pan and let them out to the battery.
OR, you can splice new cables into the harness. Home Depot has electrical connecter lugs that work. I just did it on mine. seperated them with a piece of 1/8 think rubber (after a good tape job), and then wrap it all up. I'll post now, and then post some pix in a minute.
Scaaty
What the switch probably looks like...
Scaaty
What I did to my harness..
Scaaty
Batt cable fix.....You can also stagger them. Just make sure good and insulated from each other..
compfast
Wow that's a great help.....thanks alot:)
Scaaty
No prob...stick with this post/thread and keep us up with what you come up with..
Nothing here thats can't be fixed cheap. If your switch wires are good, rest can be easy
Scaaty
Oh yeah, a heads up on cables. West Marine has 4 footers for a OUTRAGEOUS price of $35 to $45 dollars. Don't know what planet the sell too, but Autozone has 8 footers with ends for $6
compfast
Hey thanks for the heads up on the battery cables at autozone................i'll post how it all goes on this thread :) thanks again
Scaaty
Please do...lots here start a problem, we help, and sometimes we never here from them on results...
Thats the other half of ANY problem...helps us all. Good Luck, and glad to help..(we ALL learn from the stuff here....wish ya well...and if you need an new box/harness..I have contacts..)
compfast
Thanks :) I'll be getting the boat on the water in the next month so i'll post the results then
Sig_Mech
FYI:
If your control harness looks that bad then there's no telling what the engine harness looks like. If you're going to repair this harness then I would recommend that you take the cowling and covers off your engine and thoroughly check your engine harness. Look for cracks and splits on the insulation and repair as needed. While you are there, disconnect the leads to the starter and solenoid, clean them up real good and reconnect them.
compfast
Wow aswesome info guy thanks alot...................
How does the wiring harness connect to the control, sauder?/ or plug and play? :)
ricksrster
Ignition switches like the one in the picture above are soldered. some have screws.
compfast
oh thanks...I didn't realize the wiring harness is what attached to the ignition switch......I thought it attached somewhere else in the control :redface:
