FrustratedAgain
Thread starter- Joined
- Jul 2, 2003
- 1
I have a 1970 40hp evinrude with selectric shift. Just resently it started to fire on only one cylinder. Not getting a spark on one of the cylinders I checked the coils, points and condensors. All seemed OK. Put everything back together and the motor worked fine for the next hour but then quit altogether. I now get no spark on either cylinder. Checked coils, points and condensors again. All seemed OK. When I put the motor back together I get a good spark and motor runs for approximately 15 seconds and cuts out. No spark at either cylinder again. If I pull the flywheel again and check coils, points and condensors I get a spark again at both cylinders. Teh motor will run for 10-15 seconds again and then quit. Any suggestions? Is this electrical? or is it a fuel problem?<br /><br />Any Suggestions Appreciated<br /><br />Frustrated
