1970 33hp Johnson- hit a log
Dworth259
So i hit a log at full throttle and now my boat will not go fast like its suppose to. Its running like its at half throttle but i got it a wot. Went through the motor and gearcase and no damage. Possible prop is just spun or what,and how would i be able to tell.
Bosunsmate
Re: 1970 33hp Johnson- hit a log
If your engine speeds up with no corresponding boat speed- its a spun prop.
Bosunsmate
If rpm dont increase then look at your engine again.
Compression test is most important
Dworth259
Is it possible to have lost power to a cylindersince when i hit the log the motor came up out of the water and the rpms went up when it did
Bosunsmate
Maybe, compression test will tell you the score
F_R
Hope it was just a coincidence. If it did lose a cylinder due to over-revving, it probably is fatal. The vacuum cut-out switch might be the culprit, but that would be so extremely unusual that it's almost unheard of.
