1969 Mercury 1100ss tilt/trim
tomahawk715
I have a slight seal leak on one of my lift cylinders but have been unable to find anyone who sells a rebuild kit. Leads? Thoughts?
The trim cylinders on my '77 Merc IL6 were sealed with orings. The piston was sealed with a teflon seal, which required a special tool to install.
If she is leaking around the trim rod, you might go on crowleymarine and see if they have an exploded diagram of the trim cylinders. Those diagrams often give sizes for the orings. You can then order them online. Mercury may also have a rebuild kit part number, which you may find some NOS.
