1969 Mercruiser 2.5L 120 HP alternator upgrade
Catfishcabin
Some fairly certain my alternator is going out I'm only getting about 13 amps out of it and was curious if this model will fit it would be nice to have the extra amperage to make sure my two batteries stay well charged during my longer trips. This particular alternator says the size would fit but it doesn't have my year everything starts later. Thank you
https://www.powerparts360.com/after...0wlRaMo563xrRYeCcDFritXZqT-2Vb0bTgaAuEr8P8HAQ
Bt Doctur
that should be a direct bolt up.maybe just a change of belt but given your age and wiring a "Single wire" would work better
Bt Doctur
Yep, only 1 orange wire and 1 black wire. Alt is self exciting at about 1000 rpm To install a 3 wire you need a "sense and excite" circuit. 1 wire is constant 12v battery and the excite is a switched 12v to turn on the alt
Bt Doctur
What is the wiring now for your old alt, is it still the external regulator or a later model internal
