craigdaniel
- Mar 13, 2014
- 2
I have a 1969 Merc 40 1 cyl. the motor will crank and idle perfect. However once you throttle it up after about 1/4 to 1/3 throttle it dies. You can choke it right quick and it will catch back up then dies again. It will then crank right back up. I have put new gaskets, diaphragm and check valves in the fuel pump. I am running it off of the same tank and hose I use on a merc 110 that will run, so I don't think it is restricted there. I can not see any leaks in the fuel system. Any help or advice would be appreciated.
Thanks
Craig
Thanks
Craig
