1969 Johnson Leaking oil after ran
Status
Not open for further replies.
twilightstalker
First time poster so be gentle. I have a 69 25hp Johnson on my flat bottom. i have gone through and replace the seal and o ring on the shift linkage going into the gear case and replaced both of the washers on the oil drain and fill holes. totally cleaned and resealed the gearcase where it joins the lower unit. anyways i have oil leaking out of a little hole above the gearcase in the area of the lower unit that the shift linkage is in but below the seal for it. can anyone tell me what this is. the gc oil had water in it before i changed it and didnt have any after I ran it for a short while afterwards. Could this just be unburnt exhaust oil ?
lindy46
Re: 1969 Johnson Leaking oil after ran
Yup, that's what that hole does - drain water and exhaust residue from the housing. Perfectly normal. Looks like yours is draining great. Sometimes they get sealed off and don't drain properly.
5150abf
Just for peice of mind I would check the oil after it ran for awhile, that sure does loom like lower oil with water in it.
After you get a little time on it just crack the bottom drain plug after it has sat for a couple hours and see if water comes out.
ctrevis7
I had the same motor and it did the same thing, now worries its probably just the exhaust.Definetley one of the toughest motors out there
F_R
Honorary Supreme Mariner
Exhaust housing drainage. Absolutely normal and the question pops up here very often.
1946Zephyr
Yea, sometimes it comes out black. I guess it depends on what kind of oil you're running. You should take a spray nozzle to those drain hole regularly and make sure they stay clear, because if they plug up and keep water in, they'll freeze up and swell and you'll likely get a cracked lower unit.
Welcome to iboats:cool:
Juayga
Holalgo similar. Aceite y agua por los orificios de la pata. Es para preocuparse??? Adjunto foto
Status
