Hello, I'm new to this board. I recently bought a 1969 Johson 4 HP, model 4W69. It wouldn't run right. What I mean is that it would run for a little while, then shut down. BTW: it got real hot too. Through the process of elimination, I installed new points & condensers, gapped both spark plugs, new coils, new impeller (and also blew clean the water jacket), and a new head gasket. I was ready to just throw it in the lake at one point I got so frustrated and scabbed up two fingers from the pull rope. The good news is that it runs like a champ now!<br /><br />The symptoms were always that it would start cold and run. After 1 minute, the RPM would noticable slow down. After 4 minutes, the engine would quit. Engine would not start again until it was well cooled. One other significant symptom: after the engine quit each time, the top spark plug was always dry, bottom was always wet. I could have saved $75 + alot of aggrevation had I only recognized the symptoms.<br /><br />Here's my question.....I'm running this motor on a canoe. I would like to find out any suggestions on adding an integrated gas tank to the motor, and also converting to a twist-grip throttle.<br /><br />Thanks,<br />George
