1969 johnson 25hp water pump and spark problems
wagner88
I recently bought a 1969 johnson 25hp I got it running but I noticed no spark on the 2nd cylinder. I'm assuming to replace spark plugs and clean the magneto. I also noticed there was no water shooting out. Which to me I think it needs a water pump kit replaced can anyone tell me the easiest and fastest way to do it and if I need any seals. Also I noticed oil/gas coming out the exhaust would that because it was running on one cylinder? What's the gear oil for these motors?
Chinewalker
If the coils appear to be in good shape (no cracks) then CLEAN and gap the points at .020". When testing water, were you running in a barrel, water level high enough to submerge the water pump bulge area by several inches?
Oily mess is normal in a barrel. Moreso if you have a misfire as one cylinder's fuel is exiting unburned.
Fear oil is basic 90wt lower unit oil.
wagner88
I had it sumerged about a foot of the water intake. Which is behind the propeller right? The water was about 8 to 9 gallons And thank you for the other info
