1969 Johnson 20hp engine issues above idle
jodij40
We have a 1969 Johnson motor on a pontoon boat that runs fine at idle but anytime your bring up the speed it chugs or pops. The engine kind of lifts out of the water also. We think maybe it might be sucking air in the engine like a fuel line may need to be replaced but not sure if others have had similar issue. We replaced the coils and the sparkplugs
Try opening the low speed mixture needle.----And check and see if throttle plate is opening too early.
