1969 johnson 115 model m outboard jet
shinsizzle
Long time reader, first time poster. I might be hunting a lost cause, but ive been searching for a model m outboard jet pump for 2 years. I accuired a 1969 Johnson 115 for an amazing deal because it had sat for 30 years untouched. It was one of those "Ill get to it one day" jobs that never happened. I got it for nothing and it turned out to have a burnt pulse pack that I was able to replace for $150. Now it runs and is darn near new. But I live on the olympic peninsula and a jet pump is a must have for most of these rivers. Turns out the model m outboard jet is basically the rarest unicorn of a pump ever made and was disconitued long ago. Anyone with information on one of these would be greatly appreciated, or has anyone ever modified a different pump to make it work on this model. Thanks
Chinewalker
Sell the motor and get one that already has a jet pump. You'll be further ahead in the long run... Your motor has electric shift, which means you'll have no operable reverse without monkey-rigging something up to operate the reverse/neutral gate. I believe your motor also has a 4-sided driveshaft spline, which will make modifying a later jet pump problematic as most later Johnrude V4s with mechanical shift lower units had a fine spline shaft.
