Washington Sage
Thread starter- Joined
- Apr 14, 2017
- 4
Good morning all, new to the forum here. I've been lurking for a while but just joined.
I recently acquired what I believe to be a 1969 Glasspar Citation with the afore mentioned Johnson 85. The boat in pretty much in order now but I have an issue with the engine that has me scratching my head...
So, under cold start conditions it will start with little coaxing and run great for 15-20 minutes. But after this it starts to exhibit "sticking throttle" symptoms. Even moving the throttle control back to neutral position it will continue to cruise around the lake at about 1/3 power until I kill it with the key. It is then extremely difficult to restart and only runs a few minutes before shearing the flywheel key and dying.
Both times this has happened I pulled the cover and examined the throttle components and find they all operate smoothly...but find the timing stuck near full advance. I have disconnected the advance plate from it's linkage and found that the linkage moves freely but the plate will barely move.
I have dissasembled the entire mechanism, cleaned and lubed it...moves freely when cool but binds when warm. I can fond no evidence of contact or wear anywhere on the plate or nearby components. The advance plate assembly rides in a large (roughly two inch) bushing that appears in fine condition and I have cleaned and lubed with a light coat of grease.
Any thoughts or advice would be greatly appreciated, thanks in "advance" ;-)
