Welcome to iboats
First of all, what WOT RPMs are you getting with the 15" prop? That engines' WOT range is 4500 - 5500. The altitude is going to kill your power considerably, even propped in the upper half of the range. Also your carbs will be running rich, you can adjust the low speed mix, but setting 4 carbs is no fun. The high speed jets are fixed and I don't believe OMC ever offered 'Altitude' jetting.
BTW, it is not Electronic Shift. It is what's called Hydro-Electric Shift. Electric solenoids direct oil to move the shift mechanism. A well engineered system that works well if the oil is kept clean and water free. Specific props are not required by the shifting method. Parts for what is almost a 50 yr old engine are getting harder to find, but a lot are available.
The bogging... when was the last time the engine had new plugs, carb cleaning, link and sync? Dirty/misadjusted carbs and synchronization are the main causes of bogging on acceleration.
