1969 evinrude overheating at high rpm
alschrimpf
i replaced the water pump and works at low rpm but doesn't work at all at high rpm. there is no thermostat what else could be problem.
Paul Moir
Re: 1969 evinrude overheating at high rpm
Did you replace the whole water pump, or just the impeller?<br />Is there a chance that exhaust is getting under the base of the water pump and into the cooling system? Or perhaps through a crack in the casting along the aft end of the 'tower' on which the water pump sits, letting exhaust in that way?<br />Did you use sealant between the impeller wear plate (stainless) and the exhaust housing? Was the pump and impeller the same as the one you switched out?<br /><br />Since reving the engine up in neutral is a quick way of destroying it, I assume you're testing this on the boat at speed. Where is the anti-ventilation (cavitation) plate relitive to the bottom of the boat? 1 or 2 inches below it?<br /><br />How did it work before you changed the waterpump?<br /><br />Please forgive all the questions!
Namcali
Just make sure hoses are not clogged.<br /><br />Nam
Dhadley
I seen several of those that would overheat without the t-stat. The water dumped so fast it didnt fill/cool the block.
Paul Moir
This engine didn't come with a t-stat and there's no place for it - it's the same basic block and head as a '56 30hp to my understanding. It's the last big one that didn't.
Namcali
Oh, by the way, how do you know it's overheating?<br /><br />Thanks,<br /><br />Nam
