1969 evinrude johnson 85 hp v4. What motors have compatibles parts?
appleo
Any help? Figger I better get a parts motor if I can.......current motor won't reverse. Thanks for any cross reference years
Bob_VT
The older V4 had shift solenoids which are very costly. You probably have (Hopefully have) a broken wire to the solenoid and not getting into R is more then likely an electrical problem and would not require a "Parts motor" which can be tough since the electric shift V4 motors are rare.
F_R
Never go into a lower unit without first checking the electrical system. Bad shift switches and wires are far more common than internal problems.
appleo
Can you point me in the direction of the shift solenoid
