1969 evinrude 55hp model 55973
shawpdx1
just bought this boat 14' fiberglass with a non running evinrude. it last ran in 1996 ran when parked in garage. the guy said he tried to start and it backfired on start up and never ran he knows nothing about motors. arent boat motors alot like mowers with a keyway? Im positive the carbs need to be cleaned. any help or advice on trouble shooting would be great. going to do a compression test this weekend. Also how reliable are these motors with the push buttom F N R controls thanks
tashasdaddy
Re: 1969 evinrude 55hp model 55973
when they are good, they are good. but if a shift solenoid or the shift switch goes out they are bad. backfire is probably the flywheel key as you suggested,
shawpdx1
wonder where a guy could get a service manual on it. does the flywheel come off like a mower?
jay_merrill
They come off easily most of the time, if you have the right puller. You can purchase a multi-use puller from OMC/BRP (flywheel & one piece gearcase), but they are a bit pricey. Most people just buy a harmonic type puller from a local auto parts store.
Don't use anything but a harmonic type puller though. Gear pullers and the like are likely to break your aluminum flywheel, which must be pulled from the center, not the outer edge.
Also, be sure to use Grade 8 bolts of the proper size, thread count and thread depth. Failure to do this can result in broken bolts and stripped threads in the flywheel.
As TD said, the hydro-electric shift systems are sort of a mixed bag. They can be just fine, or they can be a bit of a problem because of parts availibility. The last time I looked, the shift switches are NLA, as are the lower solenoids. The wiring harness in the midsection is also NLA. That said, I have a '72 65hp (same shift as yours) which has been a really good motor for me.
Here's an analogy that will surely get me in trouble with the "PC" crowd - hydro-electric shift systems are like women. If they have been treated well and maintained properly, they are a delight. If not, they tend to be very cranky and expensive.
Service manuals are available in a number of places. You can surf online or go to EBay. I bought mine at EBay for about $15. Don't bother with the aftermarket manuals - they try to cover too many motors to be of much use.
shawpdx1
Thanks ALOT very good info. I kinda rolled the dice buying it but its very clean boat hull has never hit anything.it was advertised as a lund but the title says Puma made by sunset boat CO INC in sivlverton oregon.
Has anyone heard of them? was in biz from 74 -83. will let you guys know if I get her running this weekend. going to replace all hoses, pull carbs, commpression test. check keyway, open dist cap check points hopefully she will fire.
Texmill
I too bought an old boat with '69 Evinrude on it that hadn't run in 12 years. After replacing all the wiring, amplifier etc, I was amazed it started right up. However getting that flywheel off was a real challange. I got a gear puller off ebay, but it still took a lot of wd-40, a lot of muscle and a few lite taps with the hammer before it popped loose.
It ran, but not very fast so this winter I rebuilt the carbs and we're going to take it out Sunday and do some final adjustments. I still don't have the transmission working, but I have some new(used) solenoids to put in it.
Big Thing, it doesn't use regular gear lube in the trans, it's too thick. Use either OMC Special Blend or Dextron III (transmission fluid) Dextron is a lot cheaper. :cool:
Rodneys
I have this same motor. Actually I have 2 of this model. Spray some WD-40 around the flywheel nut and let it soake for a day or so. As for the puller, I went to HARBOUR FREIGHT and picked up one for $ 7.99 that included a 20 percent off coupon. My one motor popped when itwas running and found out it was running backwards. When you get the flywheel off, remove the stator and and dist cap. Look closely around the crankchaft and you should see what it looks like a clip spring around the shaft. This is the Anti Reverse Spring. If it is broke it will cause it to run backwards. If it looks ok don't touch it because it is very fragile if it is worn.
http://shop.evinrude.com/
