Hi all,
I have a 1969 Evinrude 55 hp that has sat for a number of years. I've given it a good clean and I've changed the ignition system to an MSD unit. I'm having an issue with the boat having no power under load.
When the motors in neutral it can rev out quiet high, as soon as I put it into gear it won't even rev high enough to get the boat out of the water. I've pulled the carbs apart and given them a good clean. I've checked the fuel pump and it's working fine. Is there anything else I should be looking at? I should also mention I have spark at all 3 cylinders and all cylinders have 130 compression.
Thanks
Thanks
