1969 Evinrude 3cyl 55hp conversion
slimdusty
Hi guys,
I've got a 69 Evinrude 55hp outboard on my 16.5ft runabout. I've been doing some research and from what I can see the motors for the 55-75hp are the same except for a few bits and pieces ie carburetors, exhaust manifold ect..... Is it possible to convert the 55hp to a bigger hp? I've got a 78 Evinrude 70hp that I can use as a parts donor.My 55hp has 130 compression on all cylinders so it's still a good strong motor and I'm running an MSD Ignition system.
Any feedback is much appreciated
Thanks
Slim
I believe the 60 hp models that came out in 1970 had an extra intake port.---------Then the 65 hp models had a totally different block with an exhaust manifold that can not be fitted to the 55 hp blocks.------So best to look for a 75 hp block / motor.
slimdusty
Thanks for the reply racerone. Would putting bigger carbs on the motor give it more power? Or will it be canceled out by the lacking exhaust outlet?
F_R
Unless you are into racing where every little bit of hp makes a difference between winning or losing, you wouldn't be able to tell the difference. Save your money for something more productive.
