1969 Evinrude 25hp idling and shifting issue
coralman
I posted last night but couldn't find it this morning so I will post again.
I am having issues getting the idle slow enough to put the motor into forward or reverse gear. I will turn the handle toward the shift position and adjust the slow speed mixture control knob to smooth it out as much as I can but can't always get the idle slow enough to properly shift. The motor will cut out. There is a really fine line. Sometimes I can get it to partially engage but then it will sound a bit choppy and then pop back into neutral. I haven't used the motor in 5 years and the last time I used it, it worked fine.
However if I do manage to get the idle low enough and I get a solid shift then it will stay there and the motor runs great.
Any ideas of what I can do to correct this?
Thanks.
